Does Anyone Have A HP W2228H?
I still have not done any of the settings waiting for my desktop to come then im going to set it up properly.
I put Transformers (DVD) on my laptop which is connected to the monitor by HDMI. It looks really good. :smashin: It also has 2x 1 Watt speakers built in. It sounds really good for 2 1 Watt speakers. :smashin:
Here are some pictures of it running Transformers.
Sorry for the quality I just used my mobile.
I really like this monitor so far it look's really nice and glossy and you can move it all over the place, it also swivels. :smashin:
It comes with everything you will need for it appart from a DVI Cable. :(
Here are some pictures of just the monitor.
Usama I have a question about your HP W2228H monitor
is your screen squashed/stretched when in other resolutions except the native one on your HP W2228H monitor ?
Because with my advent X19W monitor I got from pc world, all the resolutions(except the native one) gives me a squashed/stretched like screen, see picture below to see what I mean about squashed/stretched screen.
http://i36.tinypic.com/1in8ep.jpg
Sorry for the late replay.
Yea I think if you put it into another res it will do that. All monitors will do that.
My last LCD monitor xerox xa7-19i looked normal on all resolutions, it's just these new widescreen LCD monitors that seem to have this problem.
So does your HP W2228H monitor look squashed/stretched in other resolutions except the native one ?, the reason I ask is because the HP W2228H has a aspect ratio changing option on the monitors OSD menu.
I havent tried it in other res.
Private message me your msn, yahoo or whatever, because it would be easier to talk to you on there, because you are taking too long to reply to this thread when I ask a question, sorry lol.
Sorry, I dont use this forum that often. What is your email? Do you have MSN?
I have the 24" version of this monitor, the w2408h.
the deal with the scaling can be set in the monitor settings.
there's a setting to display the exact resolution (ie, 1024x768 will have a lot of black, unused space) to stretch while maintaining aspect ration (1024x768 will have no border on the top, but plenty on the side) or to just completely stretch, which is what it is set at default.
is there anyway to get the screen to look completely normal on 1024x768 without looking squashed or anything else unusual on that HP monitor ?
Because I have a samsung SM932GW right now and it looks squashed on the other resolutions except the native resolution, look at this picture to see what I mean http://i36.tinypic.com/1in8ep.jpg
I don't want to buy that HP monitor if it's just going to look squashed on all resolutions except the native one like in the picture I posted.
As long as you tell it to scale while maintaining aspect ratio or not to scale at all it will not change the "shape" of the image.
Usama, what do you think about it now when you have used it for a while?
And you others also who have bought it?
Looks like a really nice monitor, so im thinking of buying it just want to hear little more about it first.
It looks like a w2207h (which I just bought). Seems the only difference is a dynamic contrast ratio (meh) an a 3ms response time instead of 5ms, and a DVI port (which I wished mine had - wouldn't have needed to buy a cable for digital). If the basics are the same (and panels) I would recommend giving it a try. I love mine with a Samsung panel. Luscious!
