Flogger23m
- Jun 19, 2009
Have a fairly specific question in regards to the Fractal Design Define S and possibly another Fractal case if they use the same 3.5" HDD mounts. Is it possible to move the two rubberized noise dampeners / spacers for the screws to the rear position? Pictured here:
https://i.imgur.com/mWY5P6l.jpg
Tried pulling one apart from the front and back but it they are stuck together fairly tight. Are these non-removable? Just want to confirm before I destroy one of the mounts trying to pry it apart.
The reason I need to move the rubberized spacers / noise dampeners is because I just bought a Toshiba X300 6TB drive and it lacks screw positions in the middle area. It only has 4x screw positions, two in the front and two in the rear unlike my other Toshiba, Seagates or WD drives I've had before. I'd like to move the rubberized spacers to the rear slots so I can continue to minimize as much noise as possible as that is part of the reason I bought this case.
As a side note the screw box claims I was supposed to get enough screws for 6x 3.5" HDD mounts (for 3 HDDs total) but I only received 8 screws, just enough for two HDDs... thanks Fractal Design.
