Makave7i Tha Don
- Oct 1, 2004
It seems that probably because of it being a java based program, it doesn't load up very well when you put an SLI rig to do multi GPU rendering. It will work, but none of the buttons or anything show up until you click blindly on the screen somewhere, and then they start popping in and filling in, and then when you minimize it to system tray and maximize it again, same thing all over again.
But then turn off mutli gpu rendering and just use one card and it's fine. hmmmm.....?
thanks
Eric
thanks
Eric
