Does A8N-SLI DEL support dual core?
If the vanilla one does... The deluxe will too :).
I think all s939 mobos support dual cores now...
All except for those s939 mobos based on early steppings of the VIA K8T890 series chipsets.
As for the A8N-SLI Deluxe supporting dual-core CPU's, the BIOS version required for such compatibility depends on your particular CPU. I have an A8N-SLI Deluxe and an X2 3800+ myself -- but the mobo came with BIOS version 1011 (which doesn't officially support any of the X2 3800+'s, though it supports early X2 4200+'s and up) installed. I had to update its BIOS to at least version 1013 in order to fully support my particular CPU. (The latest non-beta BIOS release is 1016, which officially supports all but the dual-core Opterons. You'll need the latest beta BIOS -- 1017.004 -- in order to officially support the dual-core Opterons.)
