Like in my sig, I have a Sapphire X800XT 256mb (500/1000) PCIe vid card.
I currently purchased the ECS PA1 MVP Extreme motherboard (Which so far is runnin quite smoothly). But I would like to (if I can find a comparable card) try out Crossfire.
Granted I should save money for the X1900XTX's, but since I dropped approx $500+ for this card not even a year ago I wold rather try to find another X800XT master card if possible.
So far the only ones I have found on the net are the X800's with only 12 pipes instead of 16 like my card has and I don't want to loose 2 pipes just to try out Crossfire.
You all here seem to know your stuff and where to find the "hard to find" information.
I feel that no manufacturer has made an X800XT Crossfire Master card.
If you know of a place (even if it's UK, Canada) based that may have one of those I would greatly appreciate it..
Thanks
Bic
Thanks
Bic
