I have Crucial Ballistix http://www.crucial.com/store/partspecs.aspx?imodule=BL2KIT12864AA804 and my motherboard A-Bit AB QuadGT defaults to a memory voltage of 2.00v even though my mem specs are 2.2v.
When I load the software guru panel in WIn XP it reports the memory voltage as only 1.925volts.
Now, when I manually set the voltage to 2.2v... the uGuru panel shows it only as 2.04 volts. Anyone know what might be going on?
