Does a 13W3 to DVI adapter exist?
dz187
My Sun monitor has a 13W3 connector and my video card has DVI. I'm just trying to lower the amount of adapters that I have to use (13W3 to HD15 to DVI)
Haven't heard of one but you can cut out an adapter by getting either a
13w3 to vga cable
or
DVI-A to vga cable
Personally i'd probably go with the second option because the cable looks better with dual-ferrite cores (as opposed to just one ferrite core in the other cable) and the second option costs less to boot. Also: Using the shortest possible cable could only help picture quality, especially if you're running high rez + high refresh rates.
