does 7950gx2 still have power?
I have a couple of those, used them in quad-sli in a Socket 939 rig.
For $150, if you wait a couple of weeks, AMD is supposed to have something in that price range that should smoke a 7950GX2. Not to mention the 8800GT, which is hovering around $300 now, but I suspect that you'll see for closer to $200 before long.
So may answer is no. It's not a bad card, but in a couple of weeks there should much better parts for the same money or a just a little more.
Thats not a bad price for the 7950, its still a fairly worthy card, however, not all games are optimized well for dual GPUs, but still a good card. I was looking to sell my 7900 GTO for 150ish, and that GX2 is maybe 25-30% more powerful in most situations.
or better goes with x1950xt for 125us ?
IMHO, this is a little better card for a little less money. If you have a $200 budget, you should wait and see what's coming in the next couple of weeks if you can.
so better have the 7950gx2 or the x1950xtx ?
i need a card now, and some one if offering
what it is normal or cheap price for them ?
125 ? 100 ? 75 ?
125 ? 100 ? 75 ?
the 7950gx2 is better in games that don't have problems with SLi, the x1950xtx is better in games that do.
If push came to shove and you had to choose one or the other, i'd say the x1950xtx, because you'll avoid the issues with the games that don't support SLI
Yeah but thats only very few games, drivers have come a long way. I think the GX2 is a better choice.
I currently have an eVGA 7950GX2 and I don't have any problems with any games that I notice, as far as compatibility with SLI like mentioned above. Also, it still handles most newer games well. I'm planning on upgrading this Christmas, though, but that's also because I want DX10 capability and a little bit better of a card. For $150, like the people said above, you may be able to get something newer and better sometime soon, but that's not a terrible price for that card either, if you need one asap. The first game that I've had to turn graphics way down on is Crysis, of course. But other than that, new games run fine.
Theres some Crysis SLI tweaks you should check out, like setting console commands. User Larkin has some good ideas. Search his posts, you should be able to increase your FPS in Crysis.
