Dodgy 12 V rail workaround?
Alfie_dono
Well I've got a 1000W PSU from Dell. apparently it has 5 12V rails rated at 18A each
I also have two sets of 6pin power connectors/plugs for GPUs. I'm presuming that each set is linked to a separate rail (or is it that each plug has its own rail)?
Anyway I've got a gtx 570 that seems to need 20A.
So I figured that if I used 2 plugs from the same set it will be underpowered.
But what if I use one plug from each of the two 6 pin sets, does this mean I get effective 36A available? Is it even safe to do this?
Any thoughts? Thanks.
P.S. I know I should just get a better PSU, but the annoying thing is that there's a daughter board in the system (which controls all the fans and light, power button) that needs a proprietary 10 pin power connector - which this PSU obviously has but any retail one won't. And I like the Titanium alloy case too much to just get a new case.
Yes, you can use one connector from each rail. Generally it isn't recommended to do this, but in your case you might actually need that much power for the card.
As for the PSU itself, it's actually very good, so there's no reason to get another one, even if you didn't need this particular unit.
Thanks.
Now I know the PSU won't blow up if I do it! lol
The proprietary PSU does get on my nerves. It's almost 3 years old now, and after a couple of years it's probably a good idea to get something newer for reliability (then I'd need to change my case :( )
I've heard tthat someone with the same model has cut the 10 pin off and rewired it to a retail PSU, but that sounds like a risky job for me.
