DOA Gigabyte DS3? Please help
lelias2k
Hey all,
I was all happy and all that my E6300 arrived today so I could fire up my rig, but here's what's happening:
I turn it on and it flashes the power and shuts down. Two seconds later the power comes up again for about 3 seconds and shuts down again. And from then on the cycle repeats (2 sec down, 3 sec on) until I turn the power supply off.
I never hear any beeps or anything. I've tried taking the mobo out of the case, inserting the stock cooler, booting with only one stick of RAM, etc. I can't think of anything else and I've never seen this behavior before (and it's not the first rig I put together...) Since I can't hear even one beep from the BIOS I am suspecting it's a DOA, but I'm keeping my fingers crossed.
Here's what I have:
Intel Core 2 Duo E6300
Gigabyte GA-965P-DS3
OCZ DDR2 2GB (2x1GB) PC2-6400 CL 5-5-5-12 Gold GX XTC Dual Channel OCZ2G8002GK
Connect3D Radeon X1900GT 256 MB
2 x 160 GB HITACHI Deskstar T7K250
DVD-RW
FDD
Card Reader
Thermaltake Bigwater SE
APEVIA (ASPIRE) ATX-AS680W-BL ATX12V/ EPS12V 680W
Any help will be more than appreciated.
I'd suspect your ram, as the ds3 defaults at 1.8v and urs is like 2.0 or 2.1 I believe... although I'd think it would beep...
This is NORMAL for every DS3 motherboard...i think we should put this in the official DS3 forum.
your ram needs more voltage probably...boot with a cheap ddr2 stick and increase the voltage
I had incompatible ram too and at one point the board decided to endlessly restart too.
When I finally got some new ram I was nervous as heck, like what if it didn't fix it. But it kept doing the endless restart routine. Then I thought, I should turn it all off, turn the psu off, pull cable from the back, then I hit the power button and restart button several times. Figuring it might be some power issue in the mobo and this would clear it.
Turning the PSU back on I turned on the power, it did the normal shutdown right after, but this time when it came back, it stayed back.
Don't know if it could still be your ram, I think I've heard of there being incompatible ram with OCZ as there was with GSkill, that whole voltage issue.
Try checking out the Intel area in the forum at www.xtremesystems.org
Yeah, I thought about the RAM, but I was worried because there's no response from the machine before restarting. I mean, I've had RAM problems before, but there's always the feedback (sound).
Also, I've read in other forums that some people got over the RAM issue by using just one stick.
I'll try picking up some cheap RAM tomorrow at Fry's just to see if I can boot it up.
Anyway, nice to hear that some of you had the same situation and still got it to work. Better than DOA...
Thanks guys.
Yep, I had to do the same damn thing to my rig to ge it to boot the first time. I just kept switching the psu on/off and cycling the power button. After about 25 times, it stayed on and has never failed to post since.
Shawn.
I think I've already turned it on and off more than 25 times during my troubleshooting... :p
Leaving to try to get some memory at Fry's (I was there but nobody knows the memories' voltages, so I had to come back and get a list...)
Thanks guys
Thanks for your input guys. I'm typing this reply from my new Core 2 Duo machine. Not bad.
Got myself some good Corsair XMS2 and we're cruising.
I really appreciate you input.
