Comixbooks
- Jun 7, 2008
I'm just wondering if the more expensive monitor deliveries the better picture over the cheaper variations.
To a large degree, price does reflect quality. This is usually true for almost anything up to a point. At some point there is usually a halo level for a product where the amount of money spent is disproportionate to the gains received over a less expensive option. For example: Most shooters would be hard pressed to tell the difference between a $1,500 semi-custom 1911 and a custom $2,500 1911. In most cases, the less expensive one will be capable of more accuracy than the shooter is. There are few people that are proficient enough to notice the difference in the higher end option. Even a few of those are experiencing a simple placebo effect.
On the subject of monitors, you bet there is a difference. However, the monitor market is a weird one. In some cases the person looking at monitors may simply not have the exposure to the higher end displays or doesn't know enough about the subject and therefore doesn't know the difference. On the reverse side of the coin, there are people who can look at a panel and tell you right away roughly what it is and how good or bad it is. Simply looking at the specs isn't the answer either as some specs are rated differently from one manufacturer to the next. As others have stated, you have some people that are good with TN and don't really care about image quality as much as raw performance. That is, they are looking at refresh rates or response times. Nothing else really matters. On the other side, you have people like me that hate TN displays and won't use one. The image quality and viewing angles are atrocious and are therefore unacceptable. It can also depend on your needs. I've done photo editing on panels that weren't calibrated or weren't very accurate due to their panel types and it caused a problem. Basically, the photo looked fine on my screen but for everyone else it had a yellow tint.
There are also differences in cheaper monitors when it comes to eye strain. Cheaper monitors that use PWM cause me headaches. For short periods its fine but I'm on my PC more than a person really should be. Having a quality panel is essential to the experience being tolerable.
I'd also add that if you read forums like these, you might start thinking that everything on the market is garbage. But every monitor available has some issues in some area and even the best ones have their drawbacks. Right now I have one of the first gen 8-bit TN high refresh rate monitors (ASUS PG278Q) here along with an LG C9 OLED and a Samsung CRG9 VA panel. I used the TN for over 5 years and it still works fine in my gf's machine, I think it's a very good monitor that still has top tier response times and TN viewing angle issues are not a problem on it as long as you are right in front of it. It's nothing like those awful cheap monitors and laptops you see in stores where moving your head a little causes noticeable shifts. In a similar way the VA's slower black transitions and response time haven't been a real problem for me though I can agree that it is not as good as the TN and OLED. Lastly the OLED has its own issues if one were to use it as a desktop monitor (size, burn-in, font subpixel rendering is not made for its pixel structure...), mine is in TV so it's fine.
Could say the same about all panels BUT you need to remember that a lot of the big brand named panels are just rebadged HiSense or other OEM that supplies the same panels they use in their lower priced own displays to the big brand names who put a premium mark up on the same unit with their badge.
