Ya sure that 3v VCore you were trying to use didn't have something to do with it ??Originally posted by lorcani
Yeah, I don't trust the ratshack stuff. I had a bad experience, involving flames, an 1800+, and an expensive motherboard. But, thats probably my fault![]()
Originally posted by Mad_Pyro
Arctic Silver 5 can be had for $5 [3.5g]. Just shell out for it.
Originally posted by Retro Rex
Your could. But the temps will be super hot.
Try radioshack.
Originally posted by Petra
Well, you really should use some sort of thermal interface material between your CPU and heatsink be it a paraffin wax thermal pad, silicon thermal paste, or the good stuff (AS3/5, AS Ceramiqué, etc.).
BTW, you should be able to get various kinds of thermal paste locally at places like:
Fry's Electronics
CompUSA
BestBuy
Radio Shack
random local computer shops
etc.
I usually get my stuff (lights, heatsinks, fans, TIM, etc.) from either SVC or Case-Mod because I can just drive down there and pick up my order instead of paying for shipping.
you are an english major arn't youOriginally posted by PliotronX
Yes. Not since the 486 that a TIM wasn't required really. Now it is critical to occupy the air pockets in the crevices of the mating surfaces with something more thermally conductive than O2.
Originally posted by mindstormsguy
yeah, what about the store where u bought the 2100+? wouldn't they have it?
I'm not Ocing cause I don't trust myselfOriginally posted by Kendrak
The stuff we have at RadioShack is standard silicon paste. If you can wait 2 days get some good stuff off of newegg. It will help, ALOT. If your not OC-ing (I don't know why you wouldn't) the stuff at RS will do fine, much better than nothing.
Originally posted by Shinare
I'm going to have to disagree. My Athlon 950 SLOT-A had no such TIM and is still running. I had a K6-2 400MHz which required no such TIM. My daughter currently has a P4 Celeron 1.7GHz which has zero thermal compound on it. None of these computer have it and it is not necessary for running the computer. However, that said, I do agree that using a TIM will increase the effeciancy of your heatsink, but, it is not essential to it's operation.
Originally posted by NightRaven
Most of those processors are much cooler than modern CPUs anyway.
I'm sure you have a Best Buy around you somewhere, I noticed that they started carrying some generic silver paste so you could try that.
