Happy Hopping
- Jul 1, 2004
I only have a blu ray player on my PC, I'm not going to buy a blu-ray player. When on earth will we get a free blu-ray media player?
Your only legitimate solution is to rip the content from the disc to the hard drive, as there is still no actual "free" media player that will play a Blu-ray disc in a Blu-ray reader or even a burner.
You can use MakeMKV to rip the Blu-ray, all of it, to a single file on the hard drive and watch it with something like Media Player Classic Home Cinema, but you still aren't going to find anything that can play a Blu-ray disc while it's in the drive (watching natively).
Aside from that, it's either Intervideo WinDVD with Blu-ray playback capability, Arcsoft Total Media Theater, or Cyberlink PowerDVD for commercial Blu-ray playback software. Most Blu-ray drives for PCs do come with a version of one of those packages so you can make use of the drive...
I would be so annoyed if I bought a BluRay drive for my PC and found out I couldn't play BluRay movies without having to pay for a separate program!
Hmm, I am able to insert a BluRay, browse my drive to the STREAM folder from my BluRay drive and play the .mt2s file directly in Media Player Classic Home Cinema.
No ripping or converting necessary.
DAPlayer Fits the bill and it is 100% free, I use it on both of my htpcs and it works great
http://www.digiarty.com/
I finally get this to work. But do you guys get Dolby Digital 5.1? I have a integrated amp. that I connect the sound card output to the rear of the integrated amp. thru 1 analog cable. The sound card is the embedded sound card on the motherboard. The integrated amp. connects to 5.1 speakers. I have the realtek manager so far to set at virtual surround, is that the best I can do? What did you guys do on your audio?
and is there a way to disable the sub-title? As the "Disable sub-title" option is grey out
also, I notice the background sound is quite loud, but the human audio doesn't seem to be as loud. And if I increase the vol., then the human audio is good but background sound effect would become too loud. Is there a way to fix that?
