Darn, beat me to it!joemama said:no, as soon as your plane reaches US waters your laptop will immediately shut down and Bill gates gets a personal e-mail which he passes on to US customs...they will check your copy of windows when you land.![]()
InorganicMatter said:Darn, beat me to it!
You will need a converter to go from the 240V Euro power standard to the 120V American stanard, but once you convert everything will be fine.
Indeed, I have used my Dell D600 in Ireland, Germany and the USA only with a different plug-converter, same power brick. If you read the text on the brick, it should clearly state the voltage and frequency ranges for the AC input (look for the ~ symbol)eeyrjmr said:most laptop powwr-bricks are actually rated 110-250V 50/60Hz (read the brick) so all you would need is a suitable power lead to plug into the brick (standard kettle connection)
