Do they make laptop jack extension cords?
Bird222
The cable from the power brick to the laptop jack is too short. I'm wondering if someone makes an extension? If so, can anyone provide some links? Thanks!
Not that I've ever seen. People normally get standard extension cables and move the brick closer.
Yeah, once the ac has been converted to dc, you're working with a much more limited range. Voltage drops the farther DC travels, and if it gets too low then you're electronics will not function correctly (in the case of a charging cord, it may not charge the device)
