SquallRealm said:Is it okay to use a 80mm as the only exhaust of a 6 intake case?
Holy Roman Empire said:err.. squal realm... its not really a good idea to only have one exhaust and 6 intakes. generally you'd want like a 3 intake, 3 exhaust. Is your One exhaust your PSU fan? Also 80mm fans suck compared to 120mm fans. The best configuration would be an equal number of 120mm intake and exhaust fans.
templarknightx said:Actually, many people swear by positive case pressure, though 6 in to 1 out might be overkill.
mdlestat said:WAIT and buy THIS when it comes out next month.
http://www.silentpcreview.com/news452.html
mmmm...mmm...goodness
Well I think it's teh sechs.DemisE said:That has got to be the most repulsive case I have seen in a while
Hate_Bot said:http://www.newegg.com/app/ViewProductDesc.asp?description=11-133-132&depa=1
2 120MMs, and its nice quality, and its aluminum
MalfurionStormrage said:We just got that a month ago for my wife's system. Has anyone had success (nicely) removing the top (IMO, useless) wire harness to put an 80, 90, or 120 mm fan in the top? I believe the SilverStone has that capability (or is that the WaveMaster?) and I want to do that for the LGA775 computer I am building for myself next weekend...
In answer to the thread-starter's question, both the SilverStone TJ05 and TJ06 have 120mm fans.
Hate_Bot said:You can take the top USB and such ports of if you have a Coolermaster Wavemaster. It comes with a little 80mm fan grill.
I would go for the stacker
MalfurionStormrage said:I would too if I didn't take it to LAN parties.![]()
Hate_Bot said:Then get a tsunami, dual 120MMs, and a 92MM on the side, Locks for the fron bezial+sidepanel,Lightweight aluminumness, what more could you want?
MalfurionStormrage said:A top 80, 90, or 120mm fan as well.![]()
