Do they make 6-pin pci-e Extension cables?
DARQ MX
ok, as you know I have a topic on buying a new psu, but I was wondering if I can get a 6-pin pci-e Extension cable anywhere on the face of this earth. I searched all around and see nothing...
It is like no cable mfg in the world has a thought in their head that a pci-e cable can be possibly be too short in a tall case.
You should just splice your own extensions. Easiest/cheapest method.
splice, so no pins needed. Just cut it in the middle and splice in a pice so you would have two places to patch. i.e
6pin------------------------------------------PSU
6pin-------------------||---------------------PSU note || means cut
6pin-------------------|=============|-----------------------PSU =means new wire not 2 wires
