Do these voltages look fine?
x3sphere
Hi... I am having some problems with my evga X58 LE not recognizing the full 6GB RAM. While it is detected in CPU-Z, only 3.99GB usable shows up under Windows system information. I thought a CMOS reset fixed it but the problem came up again. I've also tried reseating the RAM / CPU to no avail. RAM checks out fine in memtest. Since I had most settings at auto I think it is due to an improperly set DRAM / CPU VTT voltage ratio.
Atm, I have DRAM set at 1.60v and CPU VTT at +150mv, which gives me a reading of 1.33-1.34v. Everything else is auto. So far the 6GB has been detected on multiple boots with this config.
So.. are the following readings fine? I'm not very experienced with setting voltages so I want to make sure.
Just the CPU VTT and DRAM voltages specifically, those are the only two I've changed, everything else is set at auto. But let me know if anything else looks out of place.
