Oct 12, 2011 #1 K Kuat n00b Joined Jan 20, 2008 Messages 26 Please check these timings, do they look OK to you? They were set by a profile from inside BIOS.
Oct 12, 2011 #2 F Filter [H]F Junkie Joined Dec 30, 2001 Messages 9,531 need more info but they look fine for 1600mhz memory unless you have a set thats suppose to be lower timings.
Oct 12, 2011 #3 K Kuat n00b Joined Jan 20, 2008 Messages 26 Filter said: need more info Click to expand... what kind of info?
Oct 12, 2011 #4 S SlayVus Limp Gawd 2FA Joined Jan 13, 2011 Messages 219 What RAM kit is it for example? For instance, I have two different RAM kits in my PC. G.Skill PI Black 3x2GB DDR3-1600 8-8-8-21 @ 1.6v and Corsair Vengeance 3x4GB DDR3-1600 9-9-9-24 @ 1.5v I'm running them both at DDR3-1333 8-8-8-22 ATM.
Oct 12, 2011 #5 K Kuat n00b Joined Jan 20, 2008 Messages 26 My RAM: Mushkin Enhanced Redline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Model 998691
Oct 12, 2011 #6 S SlayVus Limp Gawd 2FA Joined Jan 13, 2011 Messages 219 http://www.newegg.com/Product/Product.aspx?Item=N82E16820226050 Cas-6 | Timing - 6-7-6-18 @ 1.65v
