Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
lack of information.. idle temp = Useless comparative, you need to mention room temp at the moment of take that screenshot and also make a full load on the CPU and then the GPU.. idle temps are nothing specially if for example like me and my 3770k with the un-calibrated/faulty DTS that idle at lower temperature than ambient i can be at 25C room temp and you can see my CPU idling at 20C.. so for example open Prime95 for 10min and then you can compare with other people taking into consideration room temp and that in that screenshot you recently started your machine and have not even light loaded..
BTW if you do not have, buy a Multimeter and test those 12V lines.. 11.176V its extremely low and may damage your entire system if are correct that readings however i think are wrong.. specially with those 0.016V minimum and 0.424V Maximum Vcore.
have you many readings apps open?.. if yes close all and re-open hwmonitor but for me hwmonitor its broken since a long time ago, it does not read anything good in my machine even using the "PRO" edition..
try with aida64.. for me, the best monitoring tool.. specially good if you have a LCD keyboard
