I recently removed my h80i AIO and replaced it with a budget loop. I don't overclock, so everything is running at stock speeds and voltages.
My 4770k was running at 35-40c while playing bf1 while under the AIO.
My current loop has a dc12-400 running at 8v pushing glycol through an xspc raystorm water block, to my 1080, to a black ice extreme 92x2 radiator with 2 noctura 14mm fans in pushing into the case. This dumps into an xspc 120 radiator with 1 sp120 fan pushing out of the case. The 120 then goes back to the pump. All tubing is 3/8" id.
I have no reservoir, and run a t line to fill the system.
When playing my 4770k tops at 50c while the 1080 doesn't break 40c.
O, the cpu has been delided and repasted with mx4 (not direct die.)
This is a sff case, but the cover is removed so the internal ambient is not a factor.
