Do these temps seem normal for my situation?
Compddd
Case: Lian Li PC-X500
Case Fans: 2 fans in front, 1 in back, all 3 running at 600-800rpm at 5 volts
HSF: Thermalright True 120 Extreme with Thermalright FDB fan running at 1600rpm
CPU: Core i7 920 running at 3.8GHz with 1.16 vcore idle, 1.2 vcore under load
Ambient room temps right now are between 27-32C since I'm in San Diego and it's summer time
My cpu is idling at around 50C, and under 8 thread prime95 gets up to 85C
I've tried reseating the TRUE three times now, and get the same results
So my question is, do my temps seem normal considering the circumstances with it being hot inside my room and my case fans running low at 5V,
or does it seem like my TRUE isn't getting good contact with the cpu, etc?
Any help would be appreciated
yeah id say those temps look normal for your situation.. nothing to really worry about..
