Do SSD help with alt tabbing speeds?
tvdang7
just a simple question. Would ssd help with alt tabbing back into games?
like in modernwarfare 2 some times it takes a while to alt tab into the game i dont mind trying SSD to counter this.
Depending on whether or not you put the pagefile on the SSD. Microsoft itself recommends just that, since the usage pattern of the pagefile matches the SSD's strengths perfectly. My SSD and 8GB or RAM means that Alt-Tabbing is super smooth.
I actually removed the pagefile off my ssd to lessen the ware on the drive. With 6GB of ram the system rarely touches the page file. So I moved it to my storage disk, turned off Superfetch aswell. redirected all the browser cache directories also to the storage drive. Same for windows Temp folders.
Having enough ram so windows can cache it into memory should have more affect when alt tabbing than the ssd.
