Do Motherboards come with a modem?
Mesquite
I got my pc parts yesterday, put everything together, but I can not connect to the internet for some reason. I have LAN ports, so Im pugging in my DSL connection to them, but its not working. What am I missing?
This is my mobo here
Nope, where do I find them? Is there a CD that should have came with the mobo?
Are you plugging your phoneline directly into your LAN ports? If so, you could fry your MB if someone calls you. (rings can be up to 60V ethernet is 5V)
You have to plug your ethernet cable into a DSL modem if you are on DSL.
==>Lazn
That has to be the problem then, I will find that CD when I get home and try it.
Thanks alot for the help.
Asian Dub Foundation said:
mobos do not come with 56k modems... u have to buy them urself..
If Im using a DSL connection, I can use the LAN ports thou right?
