Do I use these settings to get max OC?
newls1
I have a couple of BIOS question reguarding OCing. Im looking to find my MAX stable OC but was wondering what I set these to?
1. Virtualization Technology = DISABLED
2. CPU EIST Function = DISABLED
3. CPU Enhanced Halt (C1E) = DISABLED
I set these all to disabled in the BIOS, but should I enable any of them? Can someone also tell me what those 3 settings do? Thank you
Honestly, they won't effect your overclock too much. As long as you're using the stock multiplier (8) you might as well enable speedstep and c1e or whatever,those are the settings that will lower your voltage and multipliers for you when in windows and not doing anything cpu intensive.
Still, I have mine disabled because the lower voltage and lower settings didn't even make a difference in temps for me.
