NKDietrich
- Jul 25, 2004
Oh god its his chart again. If I see that thing one more time I'm going to murder someone in the face.
Your right, we shouldn't have to keep bringing people up to speed on the facts...I'm seeing a pattern with your posts too -- unrealistic numbers. Try 30%. Period. In the few situations where it's any faster than that the GTX/Ultra is already running the app so fast that it really doesn't matter anymore -- 98 to 140 FPS? Good luck telling the difference.
Better be careful posting stuff like Nvidia employees statements as proof. It will get you labelled a ranting and raving fanboy very quickly. Generally speaking the company who makes the card and wants you to buy their card isn't a really reliable source.
I was wondering if I really need the 9800X2 for games like CoD4 at 1600x1050, and of course future upcoming games. It sounds so good but should I just get the G92 8800 GTS cause my resolution isn't that high?
The 8800 GTS 512MB (or the upcomming 9800GTX) would be ideal at 1680x1050. There is no reason to even consider the 9800GX2 unless you're running 1920x1200 or higher.
Thats a hell of a right hook. But ya, i decided i'm just going to save my 500 bucks and stick with my GTS512 SLI setup.
While it was developed over 4 years, you have your timelines incorrect. there are not 4 years between each generation. the GT200 or whatever the real next-get GPU is has already been in development for years. and the GT400 of whatever comes after is already in development.
Moore's law, every 18 months.... well we're at 18 months and I still stand by the opionin that the GX2 is a step backwards in terms of technology. While it may squeek out more performance on certain apps, we're droped memory lanes, they had to add 2 newer GPU's just to reach the level of performance the single 8800GTX delivered nearly 2 years ago.
And when it comes to technology, standing still is the same thing as going backwards... and by that, coming out with fractional improvements but calling it next gen, on the same GPU so really "doing nothing" it's standing still... while technology leaves you behind. The point is, there is definitly something REAL coming from Nvidia... and it's NOT 4 years away from now. it's less then 1 year.
The GX2 was just a way to buy time because Nvidia missed their chipset deadline and intel & AMD delayed their chipsets & CPU's... so Nvidia is idle.
Thinking now... didn't Nvidia come out with an internal policy to refresh their products on an even more agressive law then Moore? wasn't it like every 6 or 9 months? What happened to that law which just came into play at the 8800 launch?
In some games it is even faster and some slower and the G92 GTS OC way better and therefore keep up way too good. GTX is not a monster anymore, just a expensive solution with costly 384-bit memorybandwith compare to the cheap 256-bit bus on the G92 GTS that keep up way too good with the older monster. Sure you can find a rewiev that don´t say so and one that say so so using them for "proof" is useless since you can find what you want and turn it how you want depending on your agenda.so the GTS performance on par with a GTX?
