Do I Really Need SLI ? BIG PREDICAMENT
aldy402
Im ready to move to PCI-E and S939 . Right now I have S754 /w AGP.
Im thinking about either getting the MSI K8N Neo4 Platinum SLI Motherboard with BFG 6600GT and then leaving myself the option to upgrade to another 6600GT if needed. The only problem with this is I may never buy another 6600GT and waste an extra 50 bucks for the SLI Board but I do like the option of upgradability.
-OR-
I could get the regular MSi K8N Neo4 Platinum NON-SLI and going with a RADEON X800XL and get the extra performance I need now if neccessary.Its basically around the same price since the x800xl costs about 50 bucks more then the 6600gt but im paying for the non-sli motherboard which saves me around 50 bucks.
which one should I go with? Do I really need SLI? Will it hurt me in the future if I dont go SLI like everybody else?
My opinion: be SLI-ready. You might like to go SLI later- I have a Asus A8N-SLI with (1) 6600GT. Soon I will go with 2 6800GTs, but I'm waiting for a good price point. Just an opinion...
i was thinking the same thing but the 6600gt + sli motherboard is all I can afford,cant afford a 6800gt and I really would like those extra pipelines that a x800xl gives me.
any thoughts?
This is what I'm doing:
SLI mobo + 6600 GT
save money
Eventually go for 2 6800 GTs and sell 6600GT for small loss.
It all depends on how long you need to save...for me August will be a wonderful month. :)
yea that was my original plan also but I guess it just boils down to ATI vs NVIDIA
6600gt - 8 pixel pipelines
X800XL - 16 pixel pipelines
are these really a difference? both configs are the same price,I plan to play QUAKE 4 and FEAR with this setup
I think that Ati will be stronger than the Nvidia card. I'm not a !!!!!!, I'm just sticking with Nvidia for now, so I haven't had any practical experience with Ati since the 9800 Pro.
So I guess it's a "more now or more later" situation.
Hope that helps.
No one really needs SLI, however it does improve e-penis growth by 5-10 inches.
I'd have to dissagree with that, SLI future proofs your system and makes lots of sense $ wise for that
One little turd shows up in every thread.
No one said "you need SLI". Really only 5% percent of the population NEEDS anything over 1 ghz PCs for their daily lives. However, some people would LIKE to play their favorite games with high resolution, eye candy, etc. Otherwise, most of us could've quit upgrading around 2001.
So, answer aldy's literal question:
NO, you do not NEED SLI.
YES, you will ENJOY the benefits of having SLI
YES, if you even consider upgrading to SLI someone's going to have to make a comment about it.
Good luck in making your decision aldy :cool: .
I personaly won't get it when I upgrade later this summer. My thinking is this:
If I buy one card now, and get another down the road so I can use SLI, then I have to buy an older card to match the current one right? Chances are by the time I save enough money for another card, the next gen cards will be out. Then the perdicament is, get the older card cuz I have SLI, or just sell the old card and get the latest and greatest single card?
But of course this reasoning is thrown out the door if money isn't a concern.
I see your point/predicament. I think it depends if the next-gen cards are really next-gen. We've all sen new card cycles that are really 5-10% bumps over the last cycle. Then we see where the next cycle is revolutionary over the last. Also, it seems that Nvidia is relying on SLI to cut out an upgrade cycle, meaning new cads every 12 months instead of 6(ish) months.
bullshit
"YES, you will ENJOY the benefits of having SLI" and how can you guarantee that?
It's not just the pixel pipeline quantity but how efficient the card is at processing the material passing through the pipelines. Several benchmarks show that the 6600GT setup overclocked will perform close to that of an X800 Pro in some benchmarks. 6600GT SLI rigs perform right up close to an X850XT PE. In addition you receive the ability to take advantage of Shader Model 3.0 and more efficient SM 2.0 support.
Granted, not many current titles support SM 3.0, but you have it as an option when these titles are finally released. Also nVIDIA's openGL performance is superior in all respects to the ATI competition. This is assisted by the openGL development being the same used for the professional Quadra market, really helps to maintain their openGL lead.
I went the same route you are wondering about:
I have an MSI K8N Neo4 Platinum SLI motherboard
AMD 64 3000+ Winchester overclocked to 2GHz (might be able to go higher, but I'm comfortable here knowing it performs well and is very cool).
MSI NX6600GT-TD128E PCI-e graphics card.
Enermax EG465P-VE power supply (provides the -5V needed for the onboard Creative Labs sound chipset)
I'm also overclocking my 6600GT to 540MHz Core/ 1100MHz RAM. With 3DMARK05 I'm benching 4200 or so, I'll need to look when I get home. I'll also be able to post an ORBS link later for naysayers.
hek1 said:
bullshit
Oh, I don't know, maybe it's because more and more of the most popular games are being included in the "SLI supported" list. And many of the games that are being developed will most likely be SLI ready. Maybe because a lot of people involved with making games aren't hiding in caves afraid of new and different technologies that can improve the gaming experience.
In another thread, someone* posted this link for all the people that are constantly crapping on SLI:
http://www.umass.edu/aesop/foxgrape...rapes_trad.html
look familiar?
* credit to Rollo
problems are finally solved, I wanted SLI but wanted ATI more, im waiting for the CROSSFIRE chipset, until then ill just use my A64 3000+ with AGP
