Do I need to put more thermal paste on?
Bono
Hi guys
Quick question - I built my new system which consists of a 4400x2 processer - I have put it into the motherboard just today but I am going to put it in a different motherboard tomorrow (long story). Do I need to put more thermal paste between the heat sink & cpu if I'm just swapping it over? I only put it on today and I thought maybe I don't need to? I'll literally just be taking it from one motherboard to another. Any thoughts?
well, yes.
First you need to clean off the old thermal paste though. I would scrape as much off as you could, then clean the rest with isopropyl alcohol (90%+ if possible)
Clean both the Heatsink and the IHS of the processor.
Then just put a small dot (around the size of 1-2 grains of rice) in the middle of the IHS and let the heatsink's pressure spread it after you attach the heatsink.
You don't HAVE to do anything, but it's your choice to do it or not, imo it's always better to have a fresh coat of thermal paste on when u take the heatsink off because when u take the heatsink off you break that bond already, better to start again fresh than repair a broken one. :)
Thanks for the advice guys. I'm not actually going to be taking the heat sink off the cpu (am I right in thinking they'll pretty much be stuck together and will require some force to remove?) - I know it will be fiddly to put the processer in the new mobo with the heat sink still on it, but I was just wondering
Yes you will be taking the heatsink off. Youll have to pull the heatsink off the lift the lever on the socket. If they are stuck dont force it off. Try heating it up with a blow dryer. It's your choice on applying thermal paste but I would. Do as chingchang has outlined. Your CPU will thank you.
