do i need router, bridge, or range extender
I want to use the free public wifi that is available in my back yard, but not inside my home. (just out of range as soon as I cross the door step)
I don't have physical access to acess point.
What hardware should I buy?
I would like to plug it into an outside power receptacle on my deck and/or into a box on the deck for weather protection and then have cat 5 ethernet cable come inside and than to my desktop.
Also, if I can just extend the wifi signal that would be fine too. But, as I understand it the signal will be split/degraded
I understand that I can use 5m usb extension cables and usb power boosters(hubs?) in tandem with my usb wifi adapter to bring the signal in. (i think this would be costly)
I have a dlink wireless N router that I'm not using. But I prefer an out of the box solution that is easy to setup!
Any one can tell me what thingy (brand, model) I need or tell me another idea?
i'd get a Ubiquiti NanostationM2 loco from anywhere you want (amazon's got them)
put it on the outside of your house and point it at your public wifi, program it with it's info....
then run the cable inside to your house and plug it in to the wan port of any 'ol wireless router you want for your devices in your house....
FWIW, to clarify what each component does....
A Bridge connects two network segments together -- wireless or wired. Bridges can also be used to change the type of media information is sent across, for example a router will send a signal to a bridge, which turns the wireless signal into a wired signal for blu ray players, xbox's, etc.
A Router is used to communicate information across two networks that are not on the same group (more specifically, subnet). A prime example is how my local network in my home talks to the internet and external IP addresses through my ISP.
A Range Extender is used to amplify signals. Sometimes range extenders can also act as bridges because they can have ethernet ports available.
Some important factors in purchasing networking equipment is determining whether or not it has an internal or external antenna. External antennas can be swapped out in the event that a stronger signal is needed for whatever reason. Internal antennas are what they are.
MY RECOMMENDATION, is that you get an Amped Wireless Range extender. It has 4 Ethernet ports (get the one with Gigabit speeds, because the other one looks exactly the same but with 100Mbit speeds), and purchase a high gain antenna from amazon that has a cord so that the antenna can be mounted outside while the unit itself is inside. The antennas are dirt cheap and high quality for the most part.
If you want to have your own LAN so that neighbors on the same network cannot see your computers or gain access, purchase a router and set it up.
Then voila! You have a your own secure personal Local Area Network.
