Do i need ro replace my Power suplie?!
darkego
Just got my 6800 gt and i played pain killer for about 15 min. I left speedfan in the background run on monitor my 12v. this is what i have
12v = Max = 11.90
min = 11.58
and that’s alot of fluctuation... and i don’t like that on my new system. I heard some horror stoys about what bad vrails can do to your system. Help?
My System:
Aspire Turbo Case 500W 12V
AMD Athlon 64 3400+, ClawHammer (Running Stock)
ZNF3-250 PRO ZENITH (Bios v 1.0)
Western Digital 200GB SATA HDD
Corsair XMS 1GB(512MBx2) DDR PC-3200
Asus Black 16X DVD-ROM Drive
Aspire X-Dreamer II (Black)
BFG 6800 GT (At OC Stock) ... W00t!
Four blue 80mm fan
Windows XP Pro w\sp1
Microsoft Office 2003 Pro
If 12V moves around, it's not a big problem... 12V is used to power mechanical things (fans, HD spindles) and regulators for Vcore and whatnot. These things don't care if there's a bit of variation on the rail. 3.3V and 5V moving are what you should worry about.
also, use a voltmeter and measure at the ATX connector - the voltage sensing stuff on computers tends to be way off. On my computer, MBM reads 10.9V on 12V, but the Fluke 179 says 11.8V.
^^^^^^ what gee said
well, ok. That makes me feel a bit better. Ill have to find a voltmeter though. Don’t think i have one. Also what would be bad movement on he other 2 rails? speed fan has been giving me a little movement on my 3, but i haven’t used the voltmeter :confused:
