Etherton
Will Bang for Poof
- Aug 7, 2006
When I go to add a second EVGA 780Ti Kingpin will I need to change out my power supply as well? Currently running a BeQuiet! Dark Power 10 850w PSU, which I love! They only make 2 above 850w - 1000w and 1250w. I don't want to go overkill, just wasting electricity at that point IMO, but I do want to be safe. I do intend to overclock the system
Build:
Water-cooling system:
Build:
- Intel Core i7-4770K
- Corsair H100i 77.0 CFM Liquid CPU Cooler
- Asus MAXIMUS VI GENE Micro ATX LGA1150 Motherboard
- EVGA GeForce GTX 780 Ti Classified K|NGP|N
- BeQuiet! Dark Power 10 850w PSU
- 16gb - G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
- Intel 525 Series Lincoln Crest mSATA 240GB SATA III
- 2 - 1.5tb WD Black HDDs
- LG Bluray drive
- 10 x XSPC G1/4" to 3/8" ID, 5/8" OD Compression Fitting - Black Chrome Finish
- 1 x XSPC RayStorm Intel Faceplate - Red
- 1 x XSPC RX360 Triple-Fan Radiator V3 - Black
- 1 x Laing DDC-pump 12V DDC-1T
- 1 x XSPC Raystorm CPU/APU Copper Waterblock - Intel
- 1 x Monsoon Series Two DDC Premium Dual 5.25” Reservoir - Red
- 1 x PrimoFlex Advanced LRT 10ft Tubing - 3/8in. ID X 5/8in. OD - Pearl UV Orange
- 1 x EK-FC780 GTX Classy - Acetal + Nickel GPU block
- 1 x EK-FC780 GTX Classy Backplate - Black Rev2.0
- 6 x Corsair Air Series AF120 LED Quiet Edition High Airflow Fan
- 1 x PrimoFlex Advanced LRT 3/8in. x 5/8in. Tubing (10ft pack) - Bloodshed Red
- 1 x Koolance G1/4" Brass Inline Drain Valve Fitting - 4 Port
- 2 x XSPC G1/4" Thread 3/8" ID x 5/8" OD Low Profile Compression Fitting - Black Chrome
