do i need more power?
FraGGleR
Hi guys,
I am looking to add either a 6600gt, 6800gs, or 7800gt to the following rig. I am currently using an Antec 350W Smart Power PSU to power everything.
Athlon 64 3200+ Venice core (stock)
1 gig of OCZ ddr ram
200 gig Samsung SATA hdd
NEC 3550 DVD burner
1x 80mm intake fan
1x 120mm exhaust fan
That's it. Pretty minimal setup. If I can run the 7800gt without any problems with my PSU, then I would get that, but if not, I will probably just go with the 6600gt and wait until next year to upgrade the entire system to an M2 based system.
What do you guys think. I have a couple hours left before they won't be able to overnight it to me :) Thanks!
You would be fine on all three.
I WOULD upgrade your psu sometime soon though. Its getting close.
