Do I Need Backplate?
Funky_Junk
I just got my DFI Lanparty Ultra-D and my Zalman CNPS9500. The CNPS9500 came with a custom backplate, but I was wondering if it recomended to install the custom backplae on that mobo? Thanks.
Typically you need to. Usually a heat sink and fan come with different mounting hardware for a reason. I would definately recommend changing it out.
Installing the back plate helps to support the larger hsf and helps distribute the weight.
also there should be a sponge type pad and possibly a mylar pad to put in between the plate and mobo if the plate is metal.
