honestly in my 12 years of owning different computers, I have never had a UPS. But I do have surge protectors.
What's the difference?
Most people here seem to be looking only at the dollar value of their hardware.
That's probably because my initial question was whether I need a UPS to protect my hardware.
For maximum advantage go with a "Smart BackUps" UPS with a "True Sine Wave" output, for d@mn good overall improvement/protection any properly rated APC UPS with AVR will be fine.
If you want to save some real money, get a "Refurbed" unit with warranty & new batteries.
Dave![]()
The "Smart" and above output a "true sine wave" for maximum efficiency under battery power.What does the "Smart BackUps" line add that the regular APC UPS units don't have? Also, do you have have a place you usually buy from?
Thanks,
- JustPyro
Also do not forget to isolate you systems from spikes & lightening that can come through your NIC & phone modem.
It's not a bad idea. A UPS will maks sure that you have a constant 120v supply voltage. If you live in an area with alot of brownouts which is where the power company bumps the voltage down a bit to save money it's a very good idea. Plus in the event of an outage you will have time to properly shutdown your pc. A surge protector will protect you from a power surge but thats about it.
That's not a brown out, and power companies certainly don't initiate brown outs to try and save money. If they did intentionally initiate them then they would have waaaay too many lawsuits on their hands because of all the damage to equipment (not just solid state devices like computers, but all sorts of equipment like motors, etc.) that a brown out can cause.
What happens is that the voltage regulating equipment from the source of the power ends up going tits up and the voltage drops slowly (slowly as in a few hundred msec to a few seconds) and the protection schemes in the power grid don't see it because it's too slow to warrant a trip of a breaker. Once the relays and other protection devices in the electrical grid finally see the problem then they trip out the necessary breakers. But in that time period as the voltage goes down, load essentially stays the same, and in order to keep on supplying that load the current ends up going up sharply. It's the current spike that damages everything. I've seen what a brown out can do to a piece of machinery (most specifically an amplidyne for a turbine generator set...it's part of the voltage regulating equipment for older generators) and it's definitely not pretty. Unless you like a lot of sparks and fire...then I suppose you might think it's pretty. lol
Voltage reductions can be accidental or intentional action from the service operator. Standard reductions of 3% and 5% for purposes of conservation are common numbers.
http://www.ieso.ca/imoweb/siteShared/voltage_reduction.asp?sid=bi
http://www.ieso.ca/imoweb/ircp/VR_Testing.asp
Most UPS units probably wouldn't trip on voltages within 5%. Some with AVR (voltage boost/cut without going to batteries) may or may not. I haven't observed my UPS during one of these IESO tests to see what it did. I wasn't emailed a power event from apcupsd, however.
Need, prolly yes. I won't ever run without one again. I have to much $$ invested in my systems.
Fixt.
You can also think of it this way. Your system can cost 1000+ dollars. A good UPS is somewhere from 200-600 depending if you get one with true sine output. What's cheaper to replace?
I also still have an APC surge protector between my main pc and UPS.
I actually read on the APC website that you should not do this because it interferes with UPS. The UPS has a built in surge protector and you don't need to add an extra one.
Do NOT put an el'cheap'o power strip between the UPS & the power source (wall plug), it voids your UPS warranty, voids the insurance provided by the UPS company, and WILL interfere with operation of a "good" UPS during a sever power situation!Well it was either that or I run out of outlets and/or run multiple extension cords which I don't wanna do. I also dont wanna buy any of thier special PDUs because I don't see how they are any better than a power strip. It hasn't caused a problem yet and I've been using it this way for almost a year. Its survived over voltage, under voltage and power failures during that time.
Follow the directions, I know that you don't know why, so that is all the more reason to follow the directions!
If you don't & you have a "real problem", you will be real![]()
I think having your house wiring capable of handling your equipment with little voltage drop is probably ideal. If you have that good, you should only really need a good surge protector right? As long as your electrical company isn't sending you dirty power with improper voltages.
You didn't say that before & 99% of people use the cheapest power strips they can find!its not an el cheapo its an APC brand. I'm also using some dell rack mount PDUs. I'd hardly call dell and APC stuff el cheapo.
Those are without a doubt very good power strips, but it is still recommended not to use them, but...![]()
No one thinks they need a UPS till that voltage sag/spike fries thier computer. I got my primary UPS for $20 used (APC Smart UPS 2200va with network monitoring) and I spent $75 on the 1100VA. They both are gonna need new batteries inside of a year or so, but they protect a good $2500 of gear. Even if I had to buy those UPSes new all over again they would still cost less than having to re-buy all of that equipment. Also the price of some of that equip. is low balled because some of it was second hand. To get all of it back at full retail would average $3k+. I also still have an APC surge protector between my main pc and UPS.
Since you are using a "Smart BackUp" that generates a "True Sine Wave" this is not a problem, but if you were using a cheaper model BackUp that generates a "stepped" (modified sine wave), when on batteries, your APC Surge protector might attempt to "clamp" what it see as "dirty power spikes" when the BackUp was on batteries, this would strain the UPS & produce a low-voltage condition for the PC.I also still have an APC surge protector between my main pc and UPS.
Since you are using a "Smart BackUp" that generates a "True Sine Wave" this is not a problem, but if you were using a cheaper model BackUp that generates a "stepped" (modified sine wave), when on batteries, your APC Surge protector might attempt to "clamp" what it see as "dirty power spikes" when the BackUp was on batteries.
You are in good shape! If everyone would take "power" as seriously as you, this would be a very dull forum, which in this case would be a GOOD thing.
Best Wishes,
Dave![]()
Very Wrong, you can easily learn vicariously from reading or the [H] way, by expensive & painful experience, the choice is yours.I think having your house wiring capable of handling your equipment with little voltage drop is probably ideal. If you have that good, you should only really need a good surge protector right? As long as your electrical company isn't sending you dirty power with improper voltages.
YesSo this should be fine for my build...and its only $95 after shipping and tax?
http://buy.apc.com/commerce/storefr...product_id=BE750G&tsk=h546w&promotionID=13129
Mother nature doesn't care if your power company regulates their power to 1/1000th of a volt. Lightning can strike and fuck it all up. plus a power strip only protects against surges and cuts power to the device and doesn't allow a graceful shutdown (for low VA units) or short term continued operation (higher VA units).
Whats your DATA worth? cerainly more than $40 i'm sure.
Only if you value your hardware.And if you don't value your data so much? Then is it worth it to own one?
