Hey guys just needed some advice from the pros. I just got a new rig and I switched over some of my parts from the old rig, which includes my Thermaltake 750W PSU. I've been getting a BSOD from time to time, but I haven't remembered to copy down the message. It looked similar to the message I got before - something about "physical memory dump...remove new hardware...etc". I later found out for that problem that it was my 500W Rosewill power supply.
I'm thinking that I 'm having the same insufficient power problem again since my new VGA and CPU should require more power than my older parts. I also tried out a PSU estimator to see if this was the case, and the results came out demanding only 3 more watts.
Image of the results.
Would you guys recommend getting a 1000W PSU? Is it necessary or can I do something to make it work? Thanks in advance.
