Do I need a New PSU ?
Volkswagen
Well first of all here are my spcs
A64 3400+ Newcastle Soket 754
DFI Lanparty UT250GB
Xp90 with TT UFO 92mm Fan
2 x 512mb DDR 400 Mushkin Level I
Radeon x800XT 256mb AGP
WD Raptor 37GB SATA
Lite On CDRW 52x32x52
4x 80mm Coolermaster Fans
now my system is rock stable but I had this psu for 2+ years and it seems to still run strong as it does not give me any trouble..It the older 430W True Power dosnt even have the SatA CONNEectors on it...
My Voltages according to Bios are
+5V - 5V
+12V- 11.64 -11.71
+3.3V 3.2V
So what do u guys think am i alright or is it time for a new psu and if it is reccomend something arround 100$ bucks or so
Volkswagen said:
...my system is rock stable but I had this psu for 2+ years and it seems to still run strong as it does not give me any trouble...
Enough said. ;)
i am just concerned with the 12V rail as it jumps up and down but i guess that within antecs regulation
Yeah... That's because you're using a PSU designed for a 5V system and your CPU is 12V regulated, but you're good if you're within the +/- 5% (which would be +11.6V.)
I seriously doubt anything "bad" is going to happen to the rest of your system. If the voltage had to dip too low, you'd experience lock ups and other instabilities. Sure, you could use a new PSU eventually, but you're fine right now.
