do i need a new PSU
JR_Rider
i just got a 6800gt and a Neo2 Platinum and a 3500 winchester and the psu i have is the stock 18A turbolink that came w/ the case and i was wondering do i need a new psu. do i really NEED one cause if i dont then i dont want to.
If you're going to build a decent setup, get a better PSU....most PSU's that come in a case aren't too good. Just my 2 cents.
You should run the numbers as found in the sticky, but on the surface your PSU sounds a bit on the light side.
Also remember to subtract about 1/3 of what your PSU is rated at for heat etc. That is normal in all calculations.
Luck
