Do I need a case?
Which Ones
Do I need to have a case if I built my own computer?
Like its for working on java, html, mysql, c++, php, scripting, cs mapping, and etc.. and a little of gaming and Counter-Strike??
I have this:
Qty Product Description Unit Price Extended Price
Fans, Heatsinks (Case, CPU, Chipset)
ZALMAN CNPS7000A-Cu Pure Copper CPU Cooler for AMD XP Socket 462/ 754 and Intel Socket 478
Item# N82E16835118109
Status: In Stock
Save to Buy Later
Remove Item
$40.99
$40.99
Extended Warranty Coverage
Hard Drives
Western Digital 200GB 7200RPM SATA Hard Drive, Model WD2000JD, OEM Drive Only
Item# N82E16822144153
Status: In Stock
Save to Buy Later
Remove Item
$115.00
$115.00
Keyboards
Logitech Elite Keyboard USB/ PS/2 104keys -RETAIL
Item# N82E16823126114
Status: In Stock
Save to Buy Later
Remove Item
$29.00
$29.00
Memory (System Memory)
Corsair XMS Extreme Memory Speed Series,(Twin Pack) 184 Pin 2GB(1GB x 2) DDR PC-3200 - Retail
Item# N82E16820145486
Status: In Stock
Save to Buy Later
Remove Item
$525.00
$525.00
Monitors - CRT
ViewSonic E90B 19" CRT Monitor -RETAIL
Item# N82E16824116302
Status: In Stock
Save to Buy Later
Remove Item
$178.00
$178.00
Standard Warranty only
Motherboards - Intel
ASUS "P4P800-VM" i865G Chipset Motherboard for Intel Socket 478 CPU, Model -RETAIL
Item# N82E16813131460
Status: In Stock
Save to Buy Later
Remove Item
$91.00
$91.00
Mouse
Logitech Laser Cordless Mouse (Blue/Black), Model "MX1000" -RETAIL
Item# N82E16826104158
Status: In Stock
Save to Buy Later
Remove Item
$75.00
$75.00
Power Supplies
Thermaltake Silent Purepower 480W with Black housing - Purepower Butterfly ATX 2-Fan Power Supply, Model "W0021" -RETAIL
Item# N82E16817153012
Status: In Stock
Save to Buy Later
Remove Item
$73.50
$73.50
Processors
Intel Pentium 4/ 3.2E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
Item# N82E16819116172
Status: In Stock
Save to Buy Later
Remove Item
$225.00
$225.00
Software - Operating Systems
Microsoft Windows XP Professional w/SP2 - Retail. Model E85-02665
Item# N82E16837116195
Status: In Stock
Save to Buy Later
Remove Item
$299.00
$299.00
**This item may only be returned for a replacement of the same make/model.
Video Cards
Apollo nVIDIA GeForce 6800LE Video Card, 128MB DDR, 256-Bit, TV-Out/DVI, 8X AGP, Model "Apollo 6800LE 128" -RETAIL
Item# N82E16814140044
Status: In Stock
Save to Buy Later
Remove Item
$257.00
$257.00
Extended Warranty: $ .00
Product total: $1,908.49
or link: http://secure.newegg.com/app/shoppingcart.asp?DEPA=0&submit=view
so do I possibly need a case...I don't really want a case, because all the fans and the other crap..so do I need a case??
Unless you want your brand-new computer laying in a pile like a heap of junk, I suggest a case. I'm a little confused. Why is it that you don't want a case? Do you even understand the function of a case?
what is the function of a case...do I need to have one? cuz I saw somepeople don't need a case and their computer work fine.
A case is designed to protect your components from the random crap floating around your room. While a computer can work without one, why the HELL would you pay nearly $2000 for a computer and put a risk on it like that?
Get a case.
PS: Your post is freaking annoying. We don't need to see a copy/paste of your shopping cart to tell you this info.
laughing my fcuking ass offf
this is the funniest thread ive seen
no shit u need a case
where da fuck are you going to put all the componets in?
what are you going to do? set $2000 worth of computer equipment on your table and run it from there? it will work.. but i wouldn't do that.. get a case.. especially if you are spending that much.. .
i don't get what you are asking.. you can make a case out of a cardboard box.. you can screw your compontents to the wall.. but a case is a nice thing to have...
also. i am going to make a few suggestions..
i would get a different power supply.. thermaltake is kinda like a riced up honda in my opinion. .all so, no go.. get a good fortron, sparkle, pc power and cooling, antec.. there is a power supply section on this board.. go read what people are suggesting for your price range..
why are you getting such expensive ram? i don't see the point in 1 gig sticks right now.. they have higher latencies and cost more.. get 4 x 512 sticks.. and i can't keep up with everything, but .. PDP (patriot), pqi, and ocz have some good ram.. you can get 2-2-2 memory for less money than that 3-3-3 though..
i don't know anything about intel motherboards so i will let someone else suggest on that..
and why does winXP cost so much there? $300?? what??
this one.. http://www.newegg.com/app/ViewProductDesc.asp?description=37-102-153&depa=0 is the same thing,.. and half the price.. unless you really want a $150 box...
so.. just the money saved there will pay for a really nice case.. get a case.. seriously.. they were made for a reason.. if you want to have something small look at building a shuttle.. or something..
its OEM...and ok..i order the case too..a Thermaltake CAse.
Thanks
Yes, cases offer protection for the components inside it. Also, if the design is good, they offer cooling advantages over no case at all. You'll need all the cooling you can get for that Prescott P4, as they're notorious for running hot. Another thing cases do is make sure that everything stays together. For instance, if your video card slips out of the AGP port for any reason, you'll pretty much have to shut the computer down. Get a case, for goodness sake. You'll be glad you did.
Or you can use this
http://www.highspeedpc.com/techstation.htm
Unless you going to use Vapochill or Prometia for cooling your cpu you don't have to use computer case.
That totally rocks! It's like a gas-powered generator, but....it's a computer!
Just put it in a safe place/location :D . If you like to keep changing your computer parts this will comes handy, but don't forget to ground your motherboard.
he can't be serious can he?
On another note, I have these 2 20' plasma tv/monitors laying around and I want to hook them up to my rig. Do I need a videocard?
Also, I've tried everything possible to make sound come out of my rig. I have winamp loaded and it seems to be playing something but I can't hear it. The little green jack in the back is making no sound at all. Should I be hooking speakers into it or something?
I'm a n00b so don't flame me, any help would be appreciated.
P.S. sometimes when the power goes out my computer turns off even though I have a "power supply" is it going bad?
Umm, no offense, but if you don't know if you need a case or not to build a computer, you should:
a) Search for some articles on building your own computer on Google.
or
b) Have someone else build a computer for you.
Asking if you need a case to build a computer is a bit like asking if you need building materials to make a house.
I should bookmark this thread and come back to it when I need a good laugh.
You're going to spend 500+ on memory alone for programming and counter-strike? Yet you don't want/don't understand the function of a case? :confused:
Processors
Status: In Stock
Save to Buy Later
Remove Item
$225.00
$225.00
is 225 really retail? i didnt realize a 3.2E was so cheap
or
no its more like asking whether you need walls and a roof for your house :)
lowside67 said:
You are so fucking useless it's incredible.
The very best piece of advice any of us can give you:
http://www.dell.com
Dude, don't be so harsh, his post was funny. Granted he's useless, but I wouldn't go so far as to say he's fucking useless.
well this guy set out to completely fuk with all of you and i'd like to say it worked. wow, he is my new hero....him and chuck norris
Chuck Norris is your hero, eh?
So, you, like have one of his home gyms in each room of your house?
What the hell people? He asked a legimate question and you just slam him. How rude, lets be a little more considerate of others. I thought this was a reputable forum full of kind and resourceful people, but when I see this, it makes me feel very sorry for new comers who have simple and legitimate questions that need answering in a polite manner.
I think the better way to handle that would have been to answer his question and direct him to the Search feature of the forum or Google instead of this pointless flaming.
We were all newbies at one point, just remember that next time you have to ask a question.
$500 on memory, HAHAHAHAHAHAHAHAHAHAHHAHA uh HAHAHAHAHAHAHAHAHAH and um HAHAHAHAHAHAHAHA ok I'm done.
believe it or not, the retail package is $300. there are good reasons to buy it, too. for example, if you have an OEM copy of XP, and your motherboard dies, you may have to buy a new copy. you won't be able to activate and use it with a different motherboard, unless it is exactly the same make and model of motherboard.
at my office, our network got hit by lightning, and probably 15 motherboards with integrated NICs got trashed. we had to buy 15 new copies. at that time, it was decided that we would buy retail packaging, because you can re-use retail licenses.
we also switched some computers to windows 2000... :D
Well, sadly, I just built a new computer and have been running it without a case for about 2 months. I am building my own case, but with school and work, it has become somthing I only have an hour to do on weekends and the sort. Running without a case will work, but it just isnt reccomended. I do not like running without it, and granted it is easier to play with, reset CMOS etc, simpply isnt worth the risk. I have mine on a seperate stand under my dexk so nothing can touch it for the time being, basically taking the precautions that I can untill I finish my case.
Its not somthing I originally meant to do, and I wouldn't reccomend it, $100 for a case = worth it
GJSNeptune said:
Noobies are funny!
'specially Canadian noobies!
:p
I'll have you know I was around before you were even THINKING [H]... Mar 02 to be specific. I swore off [H] for awhile, I spent too much time here, and lo and behold my account was gone.
:D
