in a nutshell, here's what i want to do.
I have some computers that i use for work on one side of my house, they only have ethernet connections, no wireless. However, i want them to connect to the internet, but my cable modem and router are on the other side of the house. so i want something to act like a "wireless cable", i.e. - as if i had run an actual cable across the house to the ethernet switch in the office. Now my router is wireless, so i was wondering if there was a way to send the wireless signal to a device in the office that will receive that signal and feed it to the ethernet switch for the work machines to use.
now i do not need to create another subnet or anything like that. i just need to a way to get the ethernet switch to connect to the router without using wire in between them.
i'm admittedly a bit confused as to the difference between a bridge and an access point, as they both seem to claim to do the same thing. BTW, my router is a Linksys WRT54GS if that helps.
thanks for any help with this.
