Do i need a BIOS flash to support Venice cores?
Wally
I have a Gigabyte K8NF-9 nForce4 board (s939, PCI-E) and have been looking for a winchester cored 3500+ for some time to avoid dicking about with the BIOS which i'm sure i'll cock up. However, i've heard that some newer boards can support venice/Sandiego without a flash - is mine one of these? If not, what's the best way to go about flashing it, bearing in mind i don't have a processor to put in it (venice or winchester).
Okay, i really need to bump this as i've got a venice cored CPU winging its way to me as i type
if ur gonna overclock then u probably do (than with the stock BIOS) due to a newer memory controller that wont be fully compatible with the older bioses...at least i had to with the MSI Plat. SLI
Hmm, thanks, i dunno about overclocking just yet, it's a brand new build and my current PC couldn't be slower, so anything's gonna be quicker. Anyone got a definite answer?
Wally-
It will probably run without a BIOS update but why would you bother? Just flash the BIOS when you get the basic system up and running. If you were dealing with a dual core CPU then there would be the possibility of a much bigger BIOS issue as some mobo's need a single core CPU on board in order to flash the BIOS to a dual core compatible version. Venice should run fine but not optimally.
You will need to flash the BIOS so the board recognizes the Rev E microcode of the Venice core. So, simple answer is: Yes! ;)
