RancidWAnnaRIot
EspantaPajaros
- Feb 19, 2004
Hello,
here's the situation
I set up a system with a 250W power supply.
It's weird.. the system sometimes boots up and passes post and sometimes it doesn't.. sometimes it turns on correctly, but i don't hear a post beep.. what's going on here? mind you i have the BIOS set to halt if it doesn't post..
also.. sometimes when i turn off the system the keyboard lights stay on.. any clues??
I'm gonna go try and do some more trouble shooting.
I would appreciate any suggestions.. thanks..
Oh yeah.. i also tested the RAM and it seems okay.. all devices are showing up in the BIOS..
also, There is this NIC i have installed, but it was pulled out of a questionable system, cause the systems power supply died and took the mobo and CPU with it.. maybe it took the NIC too? could that cause the problem?? i'm probablly gonna remove the NIC and see what happens.. i'm also gonna un plug one of the CD drives to see if it starts posting up on every boot up...
Thanks
Thanks
