Do you have any experience? If not please don't make statements.osalcido said:general computing will not be helped by 2gb of ram if youre not even using 1gb to begin with
Last year before summer I had Athlon XP computer with 1GB (2*512MB sticks) of memory. I upgraded it to 1,5GBs (3*512MB sticks) and there was big boost in loading times and generally everything was much smoother. Then I upgraded to Athlon 64 but it didn't work with 3*512MB combo so I had to use 2*512MB so I was again back at 1GB. I used my computer with only 1GBs of memory less than a month because everything felt so lagging after 1,5GBs of memory. So I ordered a 2*1GB set and everything was so smooth compared to only 1GBs of memory. If you can spend $300+ to your GFX-card you should seriously consider buying 2GBs of memory as well. It's not an overshoot - I bet that over 50% of this forums users would notice the difference between 1GB and 2GB memory configuration, especially those high end users with $300+ GFX-cards.
