do i have to activate sound storm?
thenerd
i got an asus a7n8x-e deluxe with ss. do i have to install drivers or activate it? or is it pre activated?
just install the nforce unified drivers and that should be it no activation required
the crappy thing is your not useing soundstorm tech. unless you our useing te digtal outputs...coax or optical (depending on board) Useig the standard ports you on the AC-XX controlled audio..... sucky.... there are a few good $100 digtal recivers you can pick up to full use soundstorm...
You have to be using the Digital out for SS to work, also you'll have to turn it on in the Sound Control panel (in the speaker control tab switch it to "5.1 Speaker (Dolby Digital Live)."
ok so basically i need 5.1 speakers to get it to work, what about the digital thingy?
