@the people looking at the wattage, don't. Wattage represents a unit of work done by the current times the voltage. Instead, look at the current capacity of the PSU's lines, which is the amp rating.
Anyhow: That PSU has rails which do: +3.3V@25A, +5@25A, +12V@55A, [email protected], +5Vsb@3A.
The GTX 980 Ti requires ~20-21a stock. The 4770k requires ~13a stock, fully loaded. Then the rest of the system is probably another 10a, max. You'll probably have at least 10a worth of breathing room.
Now, if you toss in that cpu overclocking, be somewhat careful. Even with ~10a breathing room (which should be plenty for a 4770k @ 4.5) - your PSU is not 100% efficient...so you'll be closer to overloading the PSU than you might imagine.
