I don't have the foggiest idea why I might, but I keep getting bsods while I try to install windows (stop code 00X0000007E most of the time). At first I sent back the ram and the motherboard (figured the ram was bad and the motherboard just straight up died), but I can't figure it out
my system is as follows
amd x2 3800+
Biostar Nf4 Am2 ( http://www.newegg.com/Product/Product.asp?item=N82E16813138028 )
eVga Geforce 7900gt
1gb G-skill DDR2 667 (pc2 5400)
sony 16x DVD+-R
SAMSUNG SpinPoint P Series HD160JJ 160GB 7200 RPM 8MB Cache SATA
I dont think its the videocard, because (i think) I switched it out before I sent all the stuff back and I was having all the same problems.
Did I do something horribly wrong? Is it the ram again?
thanks
amd x2 3800+
eVga Geforce 7900gt
sony 16x DVD+-R
thanks
