Do I have a bad 8800gt?
ctjacket
I have a month old 8800gt. After I play Crysis for about 20 minutes I start to get artifacts (I think) on the screen. The card is completely stock; cooling and not OC'd. I have a 500w seasonic psu and a q6600 OC'd to 3.0. I played Crysis on my 7900gs with those same components and did not have any issues at all. Is it just a bad card?
Ill try and take a screenshot if I can, but basically some textures "lock" in their location on the screen and whenever I turn they stay there.
We need more info. What brand of 8800GT is it? What are the remaining system specs? What are your temperatures like? You need to monitor these while you play. Sounds like the card is overheating. Come back with this info.
evga. The fan profile was set to 30% but I turned it up to 85% via rivatuner and it is still doing that.
Gigabyte ep35 ds3l mobo
2x2g g skill ddr2 800 ram
Is there an easy way to monitor the temps while I am playing?
Also if it matters the idle temp for the video card is 46c, while the cpu is at 36c and gets do about 45c after playing any sort of games.
Monitor the temp with rivatuner. Open up the hardware monitor, play till you see artifacts and then check out the monitor and see what's been happening. If you have a 2nd monitor you can watch as you play.
That doesnt point to graphics card failure.
Try un-plugging/re-plugging it from the PCI-E slot and the power, see if that helps.
If not, your PSU is suspect. Can you try another?
That's far too cool to be a problem. Unless the sensor is not reading the temp properly. But if your fan is set to 85% it should not be overheating anyway unless the heat sink was set wrong.
Please test your card with GPU Caps Viewer and see if you get some artifacts or not and what is the highest load temperature.
When playing Crysis you can see your temps with RivaTuner via OSD (On Screen Display), but your temps are OK, I have 72 gr.C at 55% fanspeed while gaming. :confused:
Your 500W Seasonic should do the job, it's a fine PSU - eventually you can check the voltages with HWMonitor or with a DMM at one of your molex connector.
You didn't mentioned the ForceWare driver version that you're using, I had good results with the 177.83 and the Xtreme-G 177.92 ;)
Edit: Here is a video memory stress test, try it.
Only happened to Crysis? Your GPU temps is absolutely fine.
Thats a little presumptuous...:rolleyes:
It could be a bad GPU and so far only crysis has pushed it to the point of failure.
Download ATItool and urn its artifact scanner and see if it does it and what temp it does it.
nösferatu;1033078098 said:
I'm thinking about that possible bad GPU too, but:
You where confident enough to say the GPU was "just fine" based off a half a paragraph of information. Now you think it may be bad?
Yea, if an expert say so:rolleyes:
WTF is that supposed to even mean?
