Hey Guys,
Ok so I have an old case that I used to use as a server case but now I want to make it into a workstation case. The problem is that the case has 2 x 120mm fan holes in the side, and fans in the front and back of the case as well. This is way more airflow than I now need, and of course it's way too loud. I was thinking of using just the front and back fans in the case for airflow, and somehow sealing the 120mm fan holes on the side of the case. I tried just turning off the side fans but the processor heatsink+fan combo is right behind the fan holes and all the sound just comes right out of the case. I hope that made sense...
Anyways, I want to know if anything like a "fan hole cover" exists. I'm hoping that if I can cover the fan holes, coat the inside of the case in dynamat or some other acoustic dampening material, and use a quiet power supply, I will be able to make a quiet running workstation.
The case by the way is the Tornado 3000 that www.3dcool.com used to sell. The model I got had the option for the two 120mm side fans.
