My Pentium D 820 seems to be running hot and need to know if I should add a cooling fan to it to help a little. SiSoft Sandra says that it is mid 50's degrees Celcius and thinking that is too high, or do you split the temp between both cores which would make it about mid 60's Farenheit each core.
Thanks
Thanks
