_Korruption_
- Aug 22, 2002
I've had my Locked 2500+ running strong at 2.2GHz (3200+) for well over a year now (specs in sig). It has always needed 1.70V to be able to pass the standard 24hr Prime95 torture test. Recently, my system has begun to reboot itself under heavy load, like in CS:Source.
I thought it was the power supply (Antec True430). It was too noisy anyway, so I swapped it out for an OCZ Powerstream 420W. Great PSU, extremely quiet, looks great, and the rails are spot on thanks to the adjustability. Now, I expected things to get back to normal... but they didn't. I then ran the standard Memtest86+ test overnight to see if it was my TCCD acting up. I doubted it, because most TCCD is pretty solid. Sure enough, my RAM was clean.
So I've ruled out my RAM and my PSU. I'm starting to think that it could be my CPU because now, I need 1.775V just to keep it stable. I originally tried 1.75V, but that wasn't enough. The system still rebooted itself every once in a while. Oh, and it still fails Prime95, but after 19 hours, even with 1.775V.
Is it time for a new CPU? Time for a 2500+ Mobile? I'm not exactly a hardcore overclocker, but being able to run 2.2GHz with "only" 1.65V would be nice. I'd like to get back to the [H] Folding team, but I can't when my computer is unstable!
Cliffs:
1) Computer starts rebooting self under load (lightly overclocked, was always stable previously). Now fails Prime95.
2) Swapped in new PSU. Still get the random rebooting.
3) Memtest86+ comes out clean.
4) Starting to wonder if my CPU is flaking out. Needs excessive voltage just to run 2.2GHz, even then, still not stable.
Cliffs:
