Yeah, you misunderstood, sorry if I wasn't clear enough.
That plate that attaches to the motherboard, if you were to want to switch it out for another, you would have to remove the motherboard normally. This is why I was going to cut a square out of the back of the motherboard tray, just a small square that would give me access to the back of the motherboard, so that switching that plate would be easy without taking the whole computer apart.
However, if every 775 heatsink/waterblock mounts with the exact same screw setup (on the motherboard), then there is no point, as you would be able to easily switch back and forth using the same screws.
I used the same waterblock for almost 2 years so I don't know if the mountings are the same for other blocks/heatsinks.
Thanks, I'll go ahead and cut that hole soon then, since I gotta wait a few more days for my motherboard to arrive. This way I can go from air to water if I choose to in the future, without having to take the whole system apart again.
